Maverick302 Posted May 31, 2005 Report Posted May 31, 2005 Anyone have any experience with the shift pro? Do you prefer it over the shift star mod? Does it make neutral easier to find like the shift star? Thanks for the help. Quote
badcompany Posted May 31, 2005 Report Posted May 31, 2005 I run one, and it does everything it says it does. Shifts smoother and is easier to find neutral. Quote
Fireman-hott Posted June 1, 2005 Report Posted June 1, 2005 I run one and love it over stock thats for sure. I can find nuetral while the motor is running. From what I have gathered the recommendation is run one or the other, running both may cause you to double shift or something to that effect. Quote
Banshee~ Posted June 1, 2005 Report Posted June 1, 2005 I always find nuetral easyest when the trail opens up and im clicking into 2nd gear, not when im parking it Quote
FASTOYS Posted June 1, 2005 Report Posted June 1, 2005 Quote: Your going to dig the hell out of this clutch kit. Did you order the inner/outer hubs and basket? If Jeff didn't mention it to you, you may want to think about getting the shift spring mod while your clutch cover is off. HUGE difference in going through the gears QUote: I agree, it took about 5min to install the new spring and now shee shifts like a brand new bike... end quote! Quote: give JEFF @ FAST a call at 1-785-364-5325... Much cheaper than the shift pro! Quote
