how would that work cause you main jet is in the bottom of the carb not the top.
It sprays additional fuel into the venturi to compensate for a lean main jet.
It gets this fuel from the bowl.
However, how it "Leans" it out...I don't know....might have to ask a fellow dial a jet user...
You put a smaller main jet in and then the dial-a-jet puts the rest in to the carb. It sucks fuel from the bowl up to the dial-a-jet. I have Vito's version of it and it works good.
SO are you saying even if you have a smaller jet that is running lean the dial a jet will richen it up on its own without any tinkering?
No...it is not automatic.
Only automatic is fuel injection.
I'm sure there's a knob to turn or screw to turn to adjust it.
Still way easier than draining and removing the bowls...though...:)
You adjust the dial-a-jet to fine tune the jetting by turning the dial. So you don't have to go through the bother of changing main jets
