O5' shee just put on pro design cool head with 22cc domes and disconected tors wiring but left tors units on top of carbs. bike smokes horribly and is boggish
until w.o.t. bike also has toomey t5 exhaust and air cleaner kit with toomey's
recommended jetting. bike ran great until installation of domes and removing
tors wiring. any help would be greatly appriciated
you should sell it and buy a 450
369612[/snapback]
ur an idiot.
when you say its smoking is it exhaust smell or antifreeze burning? since you just installed the domes it makes me think that an o ring might be out of place allowing the motor to suck antifreeze in. check your coolant level and see if it has dropped since you put it in after the install of the domes. it might not be sucking enough to make a difference when youre WOT but just enough to fuck up the bottom end and midrange...
97sicshee posted this for me. I checked the anti freeze level and it hasnt budged.But could the 22cc domes need different jetting than stock head?
369630[/snapback]
as far as i know the 22cc domes are not much different than the stock head and shouldnt require much if any jetting change. this problem sounds different than a jetting problem. why did you remove the tors shit? did you get a kit to take it off or what? even that still doesnt sound like the problem.
I removed it to put a twist throttle on, then the problem started, so I put the thumb throttle back on thinking the problem was the carb tops from the kit.
unfortunatly, it didn't fix the problem. now I have the stock carb tops back on
and the wires are cut off and the cool head was installed at the same time.
