2strokesmoke Posted May 10, 2005 Report Share Posted May 10, 2005 i just need to know how would it change my speed if i put a 16 t on the front a left the 41t on the back i have 20s on the back for tires, cause now my first gear is too low and out of control with the 14t on the front my buddy told me to switch the back to a 38t but i have the 16 so just wanted to know what it would do thanks Quote Link to comment Share on other sites More sharing options...
baddboyy21 Posted May 10, 2005 Report Share Posted May 10, 2005 Changing the front sprocket to a bigger one will give you a higher gear ratio...and make you go faster. You need extra horsepower to pull the higher gears though. Here is a gearing calculator. It will give you a top speed estimate on each gear. http://home.earthlink.net/~gellett/banshee.htm Quote Link to comment Share on other sites More sharing options...
NEVER SATISFIED Posted May 10, 2005 Report Share Posted May 10, 2005 1 tooth in the front= 3 teeth in the rear... if you slap on a 16 tooth you may bog if you dont have the power to pull it. the benefit of a larger tooth will result in less wheel spin and top speed will be faster.. Quote Link to comment Share on other sites More sharing options...
2strokesmoke Posted May 11, 2005 Author Report Share Posted May 11, 2005 ok thanks that chart helped Quote Link to comment Share on other sites More sharing options...
03bansheeLE Posted May 13, 2005 Report Share Posted May 13, 2005 will a stock banshee have a problem pulling with a 16 tooth up front cause i have 20" tires on back and stock 14 tooth up front and it has no problem at all, will caddy in 4th gear with no problem and off the line, it will spin until i hit 5th gear. Quote Link to comment Share on other sites More sharing options...
baddboyy21 Posted May 13, 2005 Report Share Posted May 13, 2005 Most of the people running 16 tooth fronts are ported. I'd say with a stock bike you will have some problems with that large of a front sprocket. The most I'd try is a 15, but I guess it couldn't hurt to try a 16. You will definitely need a bigger chain. Quote Link to comment Share on other sites More sharing options...
NEVER SATISFIED Posted May 13, 2005 Report Share Posted May 13, 2005 whats the reason for puttin a 16 tooth in the front.. you tryin to top out.. cuz on a stock shee you gotta be crazy to run a 16 in the front and try and ride around on it like normal.. you will feel lots of bog and you will need to feather the clutch somewhat... Quote Link to comment Share on other sites More sharing options...
