I want to put a thumb throttle back on my banshee today. I have the correct cable from toomey to use with the stock thumb. My banshee came with the tors removed and a twist on it with idle screws etc. OKTHE QUESTION i HAVE IS do i have to remove the carbs entirely to put the new cable on? or can I just remove the tops and install the cable that way?? Any tips or pointers? thanks alot!! :shrugani:
Little do i know....o-well.
366407[/snapback]
Lol, that was a fair comment you made about the limited space. ... I just pictured myself doing the swap over last w/e. But my plastics and tank were removed which meant I wasn't troubled with any space issues. Even so, I still think it's possible to do with the tank still in place.
Racer714 ... It's a bit tricky, but you don't need to remove the baseplate that secures the needle. Just scrunch up the spring and push the old cable end towards the base plate and the brass cable holder should drop out (with a bit of encouragement and gravity - holding it all upside down). Getting it back in is worse.
Good luck! I was glad to see the back of mine being done. And oh, my carbs were still bloody sticking even with a new cable! I've since greased the slides and then blew up the engine checking if they were now free sliding! Life's a bitch!! :cry:
Rare.
thanks so far, do I have to grease the slides then?
366434[/snapback]
If you've never had a problem with sticking slides, then I'd leave them alone. ... I've had nothing but trouble with mine sticking and I've done it as a last resort when a brand new cable didn't solve the problem when I changed to thumb throttle.
Rare.
I used a thin smear of waterproof lithium based grease (Putoline), but I guess any type of grease would be ok. I wondered the same as you about dirt/crud getting stuck in there, but I had seen a few posts about greasing the slides so I thought I'd give it a try. I've taped up the junction box where the one cable joins into the two and greased all around the carb tops and where the cables go into the carb tops. And finally greased aroung the cable entry into the throttle casing.
Rare.
