ke398 Posted May 1, 2005 Report Posted May 1, 2005 I just picked up a 96' Banshee, and I am new to the forums. I have a quick question. The banshee wasnt kicking correctly, so I tore into it , and found it was missing a clip, I also found the idler gear has some play in it. How much play should it have before I replace it? Any help woud greatly be appreciated. Quote
Oilsmoke Posted May 1, 2005 Report Posted May 1, 2005 I like to use the Mirco fish at www.bikebandit.com for stock parts. If i remeber right that gear does have some play ( wobble side to side) it doesn't play a major in the engines normal opertion, so some play should be ok. Did you lose the c clip that holds it on. was it in the botton of the clutch cover. if so replace it with a new one. It came off for a reason. Quote
