I kicked over my banshee and i heard a really really loud backfire it sparked and a cloud of smoke followed but it didnt start next i kicked it again and it idles really low and i saw a spark come from the pipe, its not lean and the the plug on that side is really fouled, should i be concernd??
YES!!!!!!!!!!!!
Do a compression test... you will probably find it's top end time.
I had this problem once and it was actually because my engine was running very rich, the excessive amount of gas and oil fouled one of my plugs and then the other plug fired and the fuel ignited causing a very loud "crack" because there as so much fuel in the cylinder. I took my plugs out and wiped them off, wire brushed them and then ran a torch over them to heat them up a bit, then kicked the bike over a couple times with the fuel off and the plugs in to clean it out. turned the fuel back on and she sarted right up.
Darren
