he guys whats up? i just got a 98 banshee fro a pretty good deal it has a little work done to it mostly bolt ons. ther whole engine was just rebuilt and the tranny also. now i want to send it out to get powder coated and i was removing all of the parts. turns out that i get everythin off and now im stuck with a frame that has the stearing bearings stuck inside of it. that nut/screw(not sure forgot the name) that u need to remove to get to the rest of them is really rusted in there i have a tool but its not workin does anyone have any suggestions????? :wacko:
I haven't been into a steering head yet, so I can only give the general stuck bolt litany: heat, penetrant, repeat. Heating with a torch (even propane if it's all you got) will make the metal expand. Put a wrench to it while it's still hot, and you may bust it loose. Keep in mind that you don't want the bolt to expand, but rather the nut, frame, whatever is holding it; don't heat up both parts. Soaking in penetrant is nicer for the bike, but takes a long time, since that penetrant needs to soak in, often a day or 2 if it's real stuck. Combining heat (not too hot) and penetrant is a good thing to try as well. Heat helps the oil to get into where it's needed. Sometimes a judicious smack with a hammer will shock stuck stuck fastners into compliance, but be careful not to get too crazy!
Guest nightmare
Try some PB Blaster that is the best penitrating oil I have ever used.
YOu can soak it down. Your best bet is probably to fab a tool out of a big nut that will fit in there. Weld a socket extension to it and use an impact to back it out. Good Luck :shootself:
