Clamp on air filter
ARe you talking about pod filters? If you are, you need to measure the diameter of the air box end of the carbs. That will give you the measurement you need to order. I have 34mm PJ's and use a 2'1/4 Uni Pod on mine. I am pretty sure that the stock diamete size pod wil NOT fit the 33mm's
I got the pods from DennisKirk.com They had the 2 stage foam pods in stock. I needed them in a hurry.
