so the county just recently repaved our road in blacktop, which means when im draggin on the road my tires just catch like i dont know what. before they did it i could spin tires and never raise the front end which i liked. so im askin for advice now.
i cant start in second no more cause it just raises up or bogs down. it wont even try to spin. should i start in first and use a lot of clutch or start in second? ne advice is good...thx
im not sure if this matters but im runnin some bandits with lots of tread... does that matter?
start in first gear, hold your revs at the right point (takes trial and error), when they say go gradually let the clutch out and add throttle. practice, practice. you cant just rev it up and dump it on the street unless you have a street drag setup. sit up as far forward as you can and the more gas you can give. if you get frustrated go to the side of the road and grab some of that small peat gravel and put it in your starting area, that way you can scoot back a little and rev and dump like normal and you will spin out of the hole.
