kotin6 Posted April 14, 2005 Report Posted April 14, 2005 I posted this a while ago and it kind of went away. I put a new clutch cover on my shee and put new oil in and every since there has been a knocking noise from in the engine. I took the cool head off and there were no sighns of dammage in the cylinders or on the pistons or the head. I took the cover back off and everthing looks tip top in there. It seems to run fine but Im scared to run it to work or anything and have it fuck up. Anyone had simular problems or experiances? Ps I know my spelling suck and im not worried about it. Quote
ledofthezep Posted April 14, 2005 Report Posted April 14, 2005 Is it like a clunking sound or a faint rattling? May just be your impeller making a little rucuss, mine rattles a bit, but it's just the nature of the beast I guess...the impeller is still tip-top & I've never ran into troubles with it yet. Quote
kotin6 Posted April 14, 2005 Author Report Posted April 14, 2005 when i give it throttel the noise speeds up with the engine. it does it in neutral. and I checked the impaller and didnt see anything wrong. It sounds like a car knocking. Quote
NugShee Posted April 14, 2005 Report Posted April 14, 2005 take the clutch cover back off and look on the back of the cover for any wear. could be your kick start gear tapping the back of the cover. push on any of the gears you might see and make sure they are all in their proper place. make sure the kick start gear disengages when motor starts. Quote
kotin6 Posted April 17, 2005 Author Report Posted April 17, 2005 well what ever it was its fucked now Quote
87sheerips Posted April 17, 2005 Report Posted April 17, 2005 well what ever it was its fucked now 356524[/snapback] no squish region?? pistons hitting the head slightly?? Quote
Nighty Posted April 17, 2005 Report Posted April 17, 2005 yes, Did any research about what caused this? Quote
