Have pics for everything, will try to get them up shortly:
T-maxx great shape, coolhead, skidplates, probably about 10-15 tanks run through it since rebuild (including 5 for break in), chrome rims, mud tires, street rims and tires, trinity springs, engine save filter. Only thing wrong with it is that the reverse servo case is cracked (little super glue and it'd be fine, will even do it for you if you want) 300 obo
K&N filter for t-maxx $15
aftermarket pipe t-maxx $20
aftermarket dual outlet pipe $20
t-maxx .15 engine (ported) $60
t-maxx stock shocks $15
3 stock tires and rims $15
and now for the banshee stuff. Give me offers on the stuff. I'm looking for ebay prices about so save me the trouble of having to put them on there.
Bottom End: Everything is cherry on it except the bottom case. It needs to be replaced: $300
FMF Gnarlies with powercore 2 silencers
FMF Fatties, black, maybe would sell with the PC2 silencers mentioned above (only have one set)
Pro-Flo K&N filter and adaptor piece
2 K&N filters (will probably fit adaptor plate, one has stock plate that is cut that it fits on)
Stock grab bar
Stock head (perfect to send out to get milled)
whole kickstarter
2 kickstart gear assemblies (include spring and all pieces)
2 sets of stock intakes, all in great shape, soft and no cracking
2 stock reed cages, one set with carbon fiber reeds
Hot Rods crank true and welded, needs one outer bearing, rest of bearings are in spec
Stock stator
Stock clutch perch with cable (whole setup coming off bars)
8" douglas blaster rims with 20" turf tamers (60%)
9" ITP aluminum rims with beat holeshots on them (rims look perfect)
Stock front and rear gold rims, little banged up but still round and in decent shape.
All offers will be taken into consideration, check with something on ebay that has a couple hours left if you dont have an idea what to offer. Everything will be going on ebay shortly.
Edited by .
I need a coil asap do you have one and if so how much shipped?
Thanks......................
Couple Questions :D
Just quessing the Tmaxx parts are all for the .15 model?
and did the duel outlet pipe make any kind of performance difference? (good or bad)
(Been thinking about one for my 2.5maxx) and can't seem to get an answer outa anyone about that pipe set up.
thanks
Shaun
