Bansheeman1121 Posted April 9, 2005 Report Share Posted April 9, 2005 we need to know where the little black radiator hoses go to like the coolent bottle and engine bay and radiatior Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted April 9, 2005 Report Share Posted April 9, 2005 What hoses are you talking about?Are you talking about the smaller hoses?,If so they exit the frame by the top pipe hangers above the right side pipe.If this isn't what your talking about explain it better and I'll try to help you out. Quote Link to comment Share on other sites More sharing options...
Bansheeman1121 Posted April 9, 2005 Author Report Share Posted April 9, 2005 What hoses are you talking about?Are you talking about the smaller hoses?,If so they exit the frame by the top pipe hangers above the right side pipe.If this isn't what your talking about explain it better and I'll try to help you out. 352198[/snapback] yEs THose little pieces are what im refering to,i dont no where the hook up to the raditaor and coolent bottle, theres like 4 of those smaller black hoses Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted April 9, 2005 Report Share Posted April 9, 2005 (edited) One hose goes from the top of the head to the top right side of the rad.One hose runs from the top left side of the rad to the overflow bottle.Then the other hose goes from the overflow bottle to exit the frame above the right pipe.The over flow hoses run along the right side of the air box with the wiring harness. Edited April 9, 2005 by SICK BOY Quote Link to comment Share on other sites More sharing options...
Bansheeman1121 Posted April 9, 2005 Author Report Share Posted April 9, 2005 ok so the hose that goes from the top of the overflow bottle just goes to the front and dosnt hook up to anything just sits there as a drain or somthing?? And where do the overflow hoses come from like where are they hooked up to?? Quote Link to comment Share on other sites More sharing options...
Bansheeman1121 Posted April 10, 2005 Author Report Share Posted April 10, 2005 one more question to add the small hose that has the "t" thing on it,right now i have it hooked the the bottom of the coolent resivor bottle, connecting to the bottom of the "t" in the line i have the small radiator hose which comes from the water pump hooked on and then i have no idea where to connect the other piece that goes tords the front of the bike, Im doing my best to explain this thanx for any input Quote Link to comment Share on other sites More sharing options...
cdw Posted April 10, 2005 Report Share Posted April 10, 2005 Where can I get the clear rad hoses. I can't seem to find any high heat stuff anywhere. Any suggestions? Quote Link to comment Share on other sites More sharing options...
racer Posted April 10, 2005 Report Share Posted April 10, 2005 one more question to add the small hose that has the "t" thing on it,right now i have it hooked the the bottom of the coolent resivor bottle352599[/snapback] if im right thats whyt your gettin water in your oil. that T fitting is a case vent that should vent to the atmosphere. un hook it from there most deffinately. Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted April 11, 2005 Report Share Posted April 11, 2005 That T is a vent line. Quote Link to comment Share on other sites More sharing options...
