FULL_METAL_JACKT_II Posted April 3, 2005 Report Posted April 3, 2005 Hargh! Was riding last night and for about 10 min lights kept dimming on me, then finally went DEAD. engine or performance was not lost could this b Voltage Regulator???? M Quote
J-Madd Posted April 3, 2005 Report Posted April 3, 2005 Hargh! Was riding last night and for about 10 min lights kept dimming on me, then finally went DEAD. engine or performance was not lost could this b Voltage Regulator???? M 349051[/snapback] yes. See if the blue wire came uplugged from the voltage regulator (the silver box beside the cdi). It happened to me once. Quote
FULL_METAL_JACKT_II Posted April 6, 2005 Author Report Posted April 6, 2005 Checked out that blu wire still connected?>???!! I think it is the Volt. reg. hope i can get another oppinion QueeQueg Quote
ssanddemon Posted April 6, 2005 Report Posted April 6, 2005 Mine did that, it was the lighting coil side of the stator. Luckily Ricky fixed me up with a high output jobbie. Quote
98bonerSTOCKshee Posted April 6, 2005 Report Posted April 6, 2005 get a clymer's repair manual it tells you how to check all the electrical hardware with a ohm meter to determine what part of the system went bad.... Quote
J-Madd Posted April 6, 2005 Report Posted April 6, 2005 Are the bulbs blown? If they are, the voltage regulator is bad, and too much voltage was sent to the lights. (same as if it came uplugged, in my case). If not, it is most likely something else. Quote
fixitrod Posted April 6, 2005 Report Posted April 6, 2005 Are the bulbs blown? If they are, the voltage regulator is bad, and too much voltage was sent to the lights. (same as if it came uplugged, in my case). If not, it is most likely something else. 350478[/snapback] Good point about the bulbs !!!! If they are fine the lighting coil side of the stator is gone.... as long as there is no loose wire. The stator has two sets of coils. One for lighting and one for ignition. Here's a pic. Standard stator from www.rickystator.com High output (Being for lighting) Quote
ssanddemon Posted April 7, 2005 Report Posted April 7, 2005 A quick note here; I checked the stator's ohm readings according to the Clymers and it was real close to the proper readings (like a couple ohms). I said hell with it and bought a new one, and sure enuff that was it. Quote
FULL_METAL_JACKT_II Posted April 7, 2005 Author Report Posted April 7, 2005 (edited) Damn sure is that Stator!! Checked the Ohms and NOTHING!!!! Could of FK'd-it up when i was advancing my timing. SHIT!! do U think Ricky Stator will Fix it 4 me?? it is a Ricky Stator M Edited April 7, 2005 by FULL_METAL_JACKT_II Quote
fixitrod Posted April 7, 2005 Report Posted April 7, 2005 A quick note here; I checked the stator's ohm readings according to the Clymers and it was real close to the proper readings (like a couple ohms). I said hell with it and bought a new one, and sure enuff that was it. 350844[/snapback] I had one that was reading fine and it was bad At least you found the problem!! Quote
