I was pulling my clutch apart on the bench because I was splitting the cases to get my crank trued and welded when I realized my clutch basket was somewhat loose from the gear on the back, I can rotate it about 3/8". How exactly is it held on there, rivets? Should I just buy a new clutch basket and gear or can I take it apart and reattach it. I know there must be some way of doing it becasue aftermarket baskets don't come with the gear. What do you guys think?
345573[/snapback]
Sounds like the problem is the rubber donuts in your stock basket are shot. Make sure the basket you buy comes with a new set of donuts. Aftermarket baskets come with a plate and bolts to attach the whole assembly together. You will have to drill the rivets out, new basket will come with complete instructions.
