If you tighten down the flywheel properly, you will not have a problem.  It won't shear because of the lightened flywheel.
348149[/snapback]
What is the proper way to tighten down a flywheel?
That tool idea was MAT's. The guy who lives near the badlands in Indiana. He also put some "tabs" a the other end that slide into the groves on the clutch hub. Slick as hell. I haven't needed to do that yet.
You need to hold the flywheel still, and torque the nut to 60 lb./ft. of torque with an accurate, and reliable torque wrench. Not the China Piecs of shit you find at Wal-Mart. A good wrench. If the flywheel doesn't come loose, it won't break the key..
