I need some suggestions for jetting the shee after upgrading the ignition module. I just installed a gyt-r ignition module. I have t-6's, cool head, k-n pod filters, reed spacers. How many sizes larger on the mains do I need to go if any. right now I'm running 30 for the pilots, 4th clip from the top for the needles and 320 mains. It runs well with no problems.
Also which reeds are the best v-2's or v-3's. should I get different needle jets toomey/vito's.
Thanks :headbang:
Edited by rare_scottish_tree_badger
Sounds about right to me. You may just want to do some WOT plug checks and see if it looks lean. The difference in V-2's and V-3's is how they are put together, they will run the same.
