GEARMADE Posted March 18, 2005 Report Posted March 18, 2005 just got a set of deltas for free thats the best part but was worndering how to tell if the pedels need replaced before i install thanks Quote
Ducman Posted March 18, 2005 Report Posted March 18, 2005 The main sign that a reed is worn out is if it does not make a good seal with the surface of the cage, ie it doesn't lay flat on the cage surface. Look for visible signs of wear, frayed chiped or cracked edges, discoloration ect. If the reeds were used for over one year and have a lot of hours on them I'd probably replace them to be safe. Be sure to get all of the reed retainer plates installed in the same configuration as they are now if you change them. If you turn the plates around it will make the reed less stiff, wear out fast, and be unreliable. If a reed breaks off it will wreck your tip end. Quote
spoin39 Posted March 22, 2005 Report Posted March 22, 2005 Also if the reed doesn't seat on the cage, should lay flat. I would suggest using blue loctite on the threads of the screws that hold the cages together. I had one come loose...............................NOT GOOD! Quote
