GEARMADE
Everything posted by GEARMADE
  1. had a rough ride this weekend need new bars and nerf bars show me what you got
  2. yes kicked the shit out of it open throttle and all also just tryed it out on a briggs an strat motor got 95psi had to crank it alot im thinking my tester works that way and im just not turing the shee over enough
  3. my mods are noss hear 21ccdomes t5s, timming 4deg, ported,vitos ss pistons , delta 2, toomey intake and filter im at sea level
  4. here it is last year i ported my cylnders did not need a rebuild so honded it lighty an put in some vitos ss pistons put it back together wow what a difference have mabey put on 10h since starts first kick and is fast as hell just for kicks did a compression check with a new tester warmed it up ,full throtle 1 side had 50psi and the other had 60psi this has to be a bad reading the bike should not even run any words of wisdom
  5. need a bottom end for a blaster
  6. GEARMADE
    need a carb
    need a carb for a blaster 26-30mm in good shape
  7. i will take the other for a blaster
  8. need a set of 320s
  9. got any bigger than stock carbs?
  10. got a set of used set of vforce 2 having problems with the rubber boot between the carb and the cage wount go together got 2 rubber things sticking out that went inside the stock cages cant go inside the deltas please help thanks
  11. i just ordered a 4+ axel and front wheel spacers and got it today but i got rear spacers it will cost to much for shipping and restocking fee to send back so i thought you guy could use them sweet bilet alum. 2" per side new in the box never instaled 70$ shipped
  12. what kind of mods are needed to run those carbs? thats a lot of gas
  13. how much for the front shocks?
  14. need front shocks for 90cc quad need to measure 9-10" eye to eye
  15. just got a set of deltas for free thats the best part but was worndering how to tell if the pedels need replaced before i install thanks
  16. my t5 screem with porting i too do porting all so trail ride with no problems
  17. any one know how to adj. the coil pickup?
  18. i got the super stocks they run good cant tell you if they do what they say because i had some portwork done at the same time
  19. how do i adj the coil pickup?
  20. yeah thats what i thought but now it wont start
  21. the strap wrench trick worked thanks guys now i have a new problem i got a adj plate that came with no directions to install i put in on the way the stock one came off i want to run 4 deg adv what do i line the lines on the plate with?
  22. i have the puller just cant get the nut off
  23. how do i get the flywheel nut off? the motor keeps turning over
  24. need a front sprocket nut and washer for a banshee quick
  25. the lady i got them from emailed me back and said too bad and there is nothing wrong with the shocks NOTHING WRONG WITH THE SHOCKS!! i rode around my back yard and the front end felt like it is going to fall off!! bottoms out on small roots. the bad thing is they look like new. but she says she had them on her banshee and they where a little bouncy. and they where sold as is. this bitch ripped me off!!!!
