Banshee 79 Posted March 14, 2005 Report Posted March 14, 2005 I Have fuel Coming Out Of The Float Bowl Drain Tube. It Only Does It When Its Running. I Was Thinking Maybe It Is The Float Height. Any Help Would Be Appreciated. Its Coming out of the drain tube not the vent Tubes. Never had this happen Before. Thanks!!!!!!!!!!!!! Quote
bansheefreestyler Posted March 14, 2005 Report Posted March 14, 2005 are you talking about the overflow line? if you are then your floats are probably stuck open or something of the sort Quote
scotts96fast Posted March 15, 2005 Report Posted March 15, 2005 My buddy had the same problem with his stock carb.He took the carb to my buddy at the deaerl and a quick adjustment of the float and it never happen again... Quote
Banshee 79 Posted March 15, 2005 Author Report Posted March 15, 2005 My buddy had the same problem with his stock carb.He took the carb to my buddy at the deaerl and a quick adjustment of the float and it never happen again... 339207[/snapback] Thanks Guys, I took the carb off and adjusted the float height. Ill fire it up tomorrow and see what happens. Quote
