Got a 01 Banshee with the following....
K&N Filter/vented airbox
Stage 3 Dynojet jet kit
Wiseco Pistons
Boysen Power reeds & 3/8 spacers
Boost bottle
How much should i advance the timing? Im gueesing like +6 degrees?
Wiseco Pistons
Boost bottle
332860[/snapback]
+3 to +4
No pipes, +4.
Have pipes, +6.
Go big or go home.... :) Actually, I was running +7 on mine and it ran great that way, I was really happy with that setup.
I wouldn't go over +4 if I were you.  If you do, I'd suggest looking into getting your crank welded.
332871[/snapback]
I am getting ready to install a ricky stator timing plate, I'm just curious why you say that you shouldnt go past +4 without the crank being welded, how does this effect the crank?
No pipes, +4.
Have pipes, +6.
332901[/snapback]
Same with your response Sredish, how does the timing effect if you have pipes or not? I am just trying to decide how far to advance my timing, my crank is not welded, I have cpi pipes. What do you guys think?
