AtvStunter Posted February 28, 2005 Report Posted February 28, 2005 How can i figure out how to time my banshee .. and how hard is it ? Quote
1800bigk Posted February 28, 2005 Report Posted February 28, 2005 (edited) do you mean ignition timing, if so your ignition timing is fixed and to change it you have to get an adjustable timing plate or degree key. Dont know if this helps or not. Edited February 28, 2005 by 1800bigk Quote
AtvStunter Posted February 28, 2005 Author Report Posted February 28, 2005 do you mean ignition timing, if so your ignition timing is fixed and to change it you have to get an adjustable timing plate or degree key. Dont know if this helps or not. 330734[/snapback] Im takeing the crank out of mny banshee my uncle says ill have to re-time it then and thats what im worried abvout any help? Quote
frocashmoney24 Posted February 28, 2005 Report Posted February 28, 2005 you dont need to retime it. Do you have a stock timing plate or adjustable? Quote
Wallrat Posted February 28, 2005 Report Posted February 28, 2005 Naw you don't need to worry about that...The woodruff key will automatically put the flywheel right where it needs to be. Quote
