Sup yall , I got a problem with my shee and I really need to get it fixed. I just barely baught this banshee used, it an 2001. For some reason the low end is real weak, you have to really feed gas and alot of clutch. What do yall think the problem is and how to fix it. Someone told me maybe need new sprockets. Please help me out It bogs down big time also cant get into 5th gear in sand even when feathering the clutch
Edited by Yamaha 01 Banshee
Led pretty much asked what I would have, it literally could be a million things but I'd start with jetting (especially since you don't know what jets are in there now) and checking the compression. Cleaning the carbs and rejetting are pretty simple, most of all you want to make sure everything is CLEAN, take your time and don't force anything. You might scope out the Jetting FAQ below, got some stuff in there about pullin' the carbs and a whole lot on jettin'. Good luck.
If it's a jetting or compression problem it's not gonna help, but if you don't have alot of wide open places to get into 6th or ride in tight stuff all the time it wouldn't hurt (it'll accelerate quicker but you'll lose top speed). Banshees aren't known for their low-end power anyway, but the way you say it bogs it sounds like it might just be rich on the mains and/or airscrews...
