hey guys. well as some of you know i just bought a 2-1 carb. it comes with the regualr 35mm that comes with the kit and also an airstryker carb 35mm in size.can you guys tell me the pros and cons of each carb? and also both carbs are missing the nut for the main jet so could i use one of my stock jets to fix that or how do i fix that? do i need to buy a new jet for it? thats all the questions i have for now but i might be missing a few so if i think of any ill ask em after. thanks guys. later
the air stryker is the newer model
it has those littel fins to direct air over the needle
to improve the vacuum signal on the main jet??? i think
no reason not to runt he air stryker
as for the nut?
do you mean the drain cover thingy in the bottom of the fuel bowl
or the main jet itself
