OK so most of you know that I am in process of rebuilding. SO this probably wont be the last dumb one.
There is a rubber hose about 1/4 O.D. One end goes to the back of the engine right by the motor mount, then it comes up and has a T, this part goes down inside the clutch cover by the water pump. Where does the other end go? I tore her down over 2 months ago, and i forgot. banghead:shootself:
Thanks Led. Im lookin at the top of it right where it says #10. Ive already got the other 2 ends where they need to go, and by the picture it looks as though its just an overflow :shrugani:
Ok it routes up and back down below your right handle bar on the frame. It is an overflow, and theres a little clamp that holds it and what I think is the coolant overflow.
