Done alot to the motor and I think next i should move on to the carbs, is it worth the $$ also whats the upside of 1 into 2 carb setup? Ups/Downs?
I do every single type of riding so just a basic example of 2 carbs vs 1 would be helpfull thanks.
Also what size do you think i should get?
Stock Stroke
Ported Polish
Milled Head
Adv Timing
V-Force
and clamp on filters if any of these mods makes a difference.
Stock Stroke
Ported Polish
Milled Head
Adv Timing
V-Force
325052[/snapback]
For added low end and strong mid, great throttle response and good top, go for a 35mm single carb setup.
For the ultimate in mid and top, go for a pair of 28's or 30's.
I agree, do you have a set of pipes yet?
325106[/snapback]
i agree with the 35 for sinlge carb set up but if you want a lot on top you need bigger than the 30s. if you plan on doing some major mods i would say at least 33's if not 35's. 30s should get you tho if you dont think youll ever really get crazy with the motor. try to plan ahead itll save you alot of money.
well no pipes yet because motor is still not put back in bike but Rockets are the only pipes im gonna buy.
Right now im being offered some 32's for $225, is that a good deal?
I dont plan to stroke it or anything until this motor is shot because I already got it ported and polished and you guys said if i put in a 4mm I would need to get it all redone to match it. Seems like a waist right there.
Edited by 01bansheefox
