....i usually leave it connected to the swingarm and someone hold the break and a tire and lots of muscle....id use some sort of cheater pipe on that wrench at least thats what i had to do....
First off, a couple of 2" wrenches are a pretty good investment if you own a Shee. Other than that, judging by the looks of that assy, I would say that you need to use some heat. Get yourself one of those small propane tourches and heat the outside nut up pretty good and give it a try. Good Luck.
Guest nightmare
I use pipe wrenchs and cheater bars. The first time I took mine off they were so tight I had to use some top rail to a fence I had laying around. came right off.
umm im not tryin to sh*t on anyone but im pretty sure heat on a piece of heat treated steel is bad, weakens the metal, snaps when u land a hard jump. id say the pipe wrench is the best way, just opinion from a "ROOKIE" :yank:
