$K2 Posted February 10, 2005 Report Posted February 10, 2005 Hey fellas.... I have replaced my thumb throttle with a twist and heres the dealio... Put her all back together and turn the petcock to 'ON' and both Carbs start leakin, no wait, pouring avgas all over hells-half-acre! Shee starts within 2 kicks and idles fine, runs like a raped ape.. But I get fukin gas out of every damn overflow.. I have a ported shee with PJ 34's.. 58 pilot, 165 mains.. Needle is all the way ^ I think that is position #5 but correct me if I am wrong.. PLEASE HELP.. THanks!! Quote
ssanddemon Posted February 10, 2005 Report Posted February 10, 2005 Did you pull out the floats and put them back in upside-down? Gotta be something like that.... Quote
$K2 Posted February 10, 2005 Author Report Posted February 10, 2005 Did you pull out the floats and put them back in upside-down? Gotta be something like that.... 320564[/snapback] I sent the carbs along with the thumb throttle so theycould fit the new cable/twist.. As far as I know, they didnt mess with taking the carbs apart... I haven't removed the floats either.. I did have the same problem before but it just leaked from the bottom.. Not the side.. Appreciate the replys Quote
ssanddemon Posted February 10, 2005 Report Posted February 10, 2005 It leaked before? Needs carbs rebuilt/needles & seats. Probably the iffy needles dried out while the carbs were off and are leaking really bad now. The best time to have the carbs gone thru was when they were off the first time, but you have probably figured that out by now . They shouldn't leak at all unless the bike is on a STEEP slope. Quote
Otis Posted February 10, 2005 Report Posted February 10, 2005 maybe a stuck float??....try tapping on the outside of the float bowl , of each carb, a few times with the handle end of a screw driver. or float height off??.. i believe 21mm is the correct height. Quote
$K2 Posted February 10, 2005 Author Report Posted February 10, 2005 These are both brand spankin new carbs... Maybe 4 hours total on them... Could me raising the needle have something too do with it?? I am not too concerned with it leaking from the float bowl as much as I am from the air screw side of both carbs.. that has never happened.. I have had some troubles with the float bowl leak in the past.. They have done it since I first put them on.. Does someone have a link or whatever on how to adjust the float?? Thanks!! Quote
Otis Posted February 10, 2005 Report Posted February 10, 2005 bend(with fingers), and measure(with tape measure, card board cut out, lolly pop stick........) Quote
$K2 Posted February 10, 2005 Author Report Posted February 10, 2005 measuring part isnt a problem.. If I need to adjust them, whats the steps?? Thanks for the input fellas I do appreciate it! Quote
$K2 Posted February 10, 2005 Author Report Posted February 10, 2005 Right on bro thank you! I had that link before but lost it.. Appreciate it! Quote
