Fellow HQ'ers...just installed +4 swingarm, new 13 tooth sprocket/41 in rear, and new DID chain in rear. Installation went very well. I think I may have cut chain a link too short though. I have about 3/4 inch of play with no weight on bike...about 1/4(maybe) with weight on bike. Any how, runs fine until I try to gas her up a little. It almost feels like the engine does not want to go any faster. Nothing is binding...axle/carrier/wheels,sprockets,chain all turn freely. I did remove parking brake and still have the TORS on, any ideas?
How did you remove the parking brake? If you just unplugged the wires from the clutch perch, then that is your problem. You need to follow the wires back to near the steering stem and disconnect them there.
Thanks again guys, I unplugged the connector @ steering stem area from the clutch perch as suggested, and that did the trick. :cheers:
