Just put on the kit from janssens, the kit came with no directions. I dont know if I put on the top a arms on the right sides. For some reason I cant adjust the toeing in of the wheels any more than this. Please give me some advice guys.
no that dont look right man did you get the longer tie rods with the kit i think you need to adjust the tie rods
Edited by kw04
Yeah, the kit came with extended tie rods I adjusted them the most I could. Maybe I should try swaping the top a arms, from left to right. banghead
This is the top shot of the left a arm, does it look like the right one for this side?
Or maybe it is the bottom a arms that are not allowing me to adjust the toe out?
Edited by 1sreamin350
the camber is way off, the tires are not even close to comin out straight up and down, try pulling out teh bottom aarm ball joint, and pusing in the top one, then adjust the tie rods from there
