1sreamin350 Posted February 4, 2005 Report Posted February 4, 2005 Just put on the kit from janssens, the kit came with no directions. I dont know if I put on the top a arms on the right sides. For some reason I cant adjust the toeing in of the wheels any more than this. Please give me some advice guys. Quote
kw04 Posted February 4, 2005 Report Posted February 4, 2005 (edited) no that dont look right man did you get the longer tie rods with the kit i think you need to adjust the tie rods Edited February 4, 2005 by kw04 Quote
1sreamin350 Posted February 4, 2005 Author Report Posted February 4, 2005 Yeah, the kit came with extended tie rods I adjusted them the most I could. Maybe I should try swaping the top a arms, from left to right. Quote
1sreamin350 Posted February 4, 2005 Author Report Posted February 4, 2005 (edited) This is the top shot of the left a arm, does it look like the right one for this side? Or maybe it is the bottom a arms that are not allowing me to adjust the toe out? Edited February 4, 2005 by 1sreamin350 Quote
H250RHATER Posted February 4, 2005 Report Posted February 4, 2005 they look right is your toe set right Quote
kenr74 Posted February 4, 2005 Report Posted February 4, 2005 Man either way you suck. That setup is on my wish list! Quote
kw04 Posted February 4, 2005 Report Posted February 4, 2005 yea man the toe adjust ment is off whats it look like when your sitting on the bike Quote
frocashmoney24 Posted February 4, 2005 Report Posted February 4, 2005 the camber is way off, the tires are not even close to comin out straight up and down, try pulling out teh bottom aarm ball joint, and pusing in the top one, then adjust the tie rods from there Quote
ledofthezep Posted February 4, 2005 Report Posted February 4, 2005 CLICK HERE - Gyide on setting camber & castor. Quote
