Dakota02 Posted January 24, 2005 Report Posted January 24, 2005 do u guys think that the ptr- high revs would work good with the gorr woods port. i want 2 get all of that bottom and mid that the woods port gives, but i want good top-end power 2. Thanx for replies in advance. Im playin around with ideas for wen rebuild time comes, and ive decided 2 either get ptr mids or high revs with the woods port. Quote
bigboybanshee Posted January 24, 2005 Report Posted January 24, 2005 I can tell you now that you won't have practically any top end at all with the mids, and I heard the high revs only give you a tad more than the mids do. Now, as far as the porting goes, I know sredish has the PT mid / Gorr port combo, he would be able to tell you how strong it is.... Hopefully within the next 6 months I'm going to be sending a set of cylinders to Gorr to port them for me, and I run the PT mids. If you're looking for other suggestions on a pipe setup with Gorr porting, you could pm stclarke, he had the Gorr port running T5's, I can imagine he saw some top end and had the solid low end from the porting... Quote
tats4life Posted January 24, 2005 Report Posted January 24, 2005 i've always run pt mids and have had tons of top end, i'm going to run high revs on my patriot mx port....it's gonna haul some serious ass Quote
Dakota02 Posted January 25, 2005 Author Report Posted January 25, 2005 thanx for the info guys. For those that have the ptr high-revs, do they still have good bottom to. Quote
Banchetta Posted January 26, 2005 Report Posted January 26, 2005 I have both. The high revs shift the curve slightly, not as much as I'd expect...If your looking for lots of low end , then definately go for the Pt mids, hands down you won't regreat it. They don't rev as high, but have more torque and can pull a larger gear giving you the top end of a high rev and better abilitly to slow down and get back on it w/o shifting as much...If you ride 90% of the time in 1-4 gears then get the mids... Quote
Dakota02 Posted January 26, 2005 Author Report Posted January 26, 2005 alright, i think ill go with the mids. Ill just set my shee up 2 have awesome torque so i can pull higher gearing. THen ill have good top-end 2. I also like 2 run 22 inch tires. So thanx for the info, u guys on the HQ are really helpful. Quote
