I WAS WONDERING IF IT WOULD HURT TO SAND AND POLISH THE DOME ON MY BANSHEE HEAD. IT HAS SOME NICKS IN IT FROM A COUPLE BLOW UPS, WOULD IT HURT TO SAND THEM OUT AND POLISH. ALSO WOULD IT HURT TO POLISH THE INTAKE SIDE OF THE CYLINDERS. THANKS IN ADVANCE :cheers:
Edited by blaster250
No it won't hurt as long as you don't remove too much material with sanding. Though I doubt you would be able to remove much. Keep the sanding light. Polished intakes are really useless and they need to have a certain rough texture. If you want to polish something with a little benefit, polish the exhaust port. This helps with cooling effciency more than anything.
310795[/snapback]
yyup :clap:
Make sure you don't sand the head gasket surface, unless you do it evenly on a flat surface plate. Won't hurt to clean the nicks up in the domes.
