You probably can't make that on gas with a stock stroke or big bore. It would take at least a 7mm stroker to do that on gas with stock cylinders. You might get close if you use alky and a little nitro mixed in or NO2. A cheetah cylinder will get into the 90's on gas.
  • 3 weeks later...
:yank::shootself:banghead
It IS absolutely possible and has allready been done....many moons ago......
89 RWHP and 49.6 ft/lbs Torque
350 - Stock cylinders - on Gas - 54mm crank - 4.1`s in 300ft with 180lb rider - stock chassis. :headbang:
Edited by Forcefed
i think its possible but hard to do.i run a motor that is all stock except for a big reed conversion,mild port work ,milled head,toomey pipes and 34pj's and at the time they dynoed it it was putting out around 82 hp on gas.
wow those are some nice numbers
316536[/snapback]
Thanks....wonder what kind of #`s the bike was puttin down when it was being sprayed this summer ? ....not that #`s really matter at all anyways.....
  • 2 weeks later...
Jeff Weindorff of Fast Racing has a 350 drag motor on alky that has put out 98hp several times on the dyno. probably somewhere around high 80's to 90 on gas. Race Gas that is.
