smokin350 Posted January 8, 2005 Report Posted January 8, 2005 (edited) what's up guys i'm going to glamis next month and i was wondering what size sand paddles and what kind i should get? Usually i use ITP SAND STARS in a 20x11x9 but now i have a completly different motor pumping out 80 to 90hp don't know yet still waiting for the dyno run, with a +4 Alba swingarm and a complete lonstar rear set-up sproket hub, brake hub, wheel hubs,lock-nut, and lonestar axle with a dual rate fully adjutable elka shock. in the front i have the 2+1 alba pro-comp a-arms with dual rate piggy elka's, and i use the ITP SAND STARS in the front 21x7x10 and they work awesome. I was thinking of getting the ITP SAND STARS in a 22x11x10 cause i think i the 20's will just spin to much and before u know it i'll be sitting on the skid plate. Or i was thinking some SKAt-TRAK haulers or the extreme grip or the rippers but if i got the rippers what size, and 8 paddle or 10 PADDLE which is better and why more or less paddles. sorry for the novel guys just wanna get shit right the first time. P.S. I PLAN ON DUING ALL TYPES OF RIDING THERE NOT JUST DRAG RACING BUT ALL AROUND DUNE CRUIZING,HILL CLIMBING, DRAGING THANKS. Edited January 8, 2005 by smokin350 Quote
FIRST BANSHEE Posted January 8, 2005 Report Posted January 8, 2005 I run the extremes, 20-10-8, 10 paddle they work great for me. I don't have nearly the HP you do. For your HP I would get at least a 22-10 with a 10 paddle. call skat-trac and see what they suggest. Quote
Big Blue Posted January 8, 2005 Report Posted January 8, 2005 21 or 22 inch tall tire in a 9 paddle hauler unless you want to keep the v blade design the go with the sand stars again. Quote
smokin350 Posted January 10, 2005 Author Report Posted January 10, 2005 thats what i was thinking to to go with the 22 inch tire how much turning disability would i lose if i didn't go with the v blade like sandstar and went with the straight cut like the hauller and how do you know how many paddles to pick 8,9,10 which is best for me. Quote
RNBRAD Posted January 10, 2005 Report Posted January 10, 2005 I went from a sand skate v paddle to 10 paddle extreme haulers. I didn't notice little if any difference in turning ability. Pretty much the same. For all around duning I would go with a 20 to 21'' tire. 22's and above are more for dragging and you will lose some slideability with tire roll flex. I use the 20's and they do everything well. Though I'm thinking of getting some 22's just for when I like to drag. It's up to you but the 20'' tire will definitely out handle the 22''. It seems your set-up is more geared for handling versus straight line speed. Quote
smokin350 Posted January 15, 2005 Author Report Posted January 15, 2005 i'm still confused on what tire to pick i think i'm gonna get the SANDSTARS in a 22x11x10 u guys think that is good or should i go with the 20x11x10 i figure with all the power i'm gonna have the 22's would be better traction or should i not even go with the sandstar and go with somthing more like the HUALER and what size and how many paddles could i would like to order this stuff on monday thanks. Quote
RNBRAD Posted January 15, 2005 Report Posted January 15, 2005 Definitely get a hauler whatever you choose. 20'' 10 paddle extremes will be plenty of paddle for your motor. Quote
FIRST BANSHEE Posted January 15, 2005 Report Posted January 15, 2005 i'm still confused on what tire to pick i think i'm gonna get the SANDSTARS in a 22x11x10 u guys think that is good or should i go with the 20x11x10 i figure with all the power i'm gonna have the 22's would be better traction or should i not even go with the sandstar and go with somthing more like the HUALER and what size and how many paddles could i would like to order this stuff on monday thanks. 307049[/snapback] I don't have any where near 80-90 hp, and run 20-10-8 10 paddle extremes and hook ok, with your hp you might try to find a set of 21-12-8 10 paddle extremes, skat-trac said they stopped making them but i've seen them at a few stores. Quote
05bansh Posted January 16, 2005 Report Posted January 16, 2005 I am running Skat Trak 22x11x8 8-paddle. Awesome hook up for climbing! Except you will probably want to drop to a 14 tooth on your front sproket to compensate for the bigger tire. Quote
Oilsmoke Posted January 16, 2005 Report Posted January 16, 2005 I would test out your old tires first and see how they did before I drop the cash. I had 21x12x8 8 paddle haulers and switched to a 21x12x8 9 paddle Hauler and my shee pushes more in the turns than before If your plans are for More play than stay low on the paddle count or v wedge desgins. If you need the hook up for hill shootin 9 paddle extreme or 10 hauler in 22 would be my choice. Quote
