OK i have more problems. I wasnt getting spark, so i disconnected the TORS. however, now i am not getting fuel. plugs arnt getting wet. However, this is the strange part, it does run when i blow compressed air through one of the overflow hoses coming out of the carb. when i do that, it starts right up. when i blow the air through, the gas inside the tank gurgles, and gas shoots out of the carb, although i cant see where it is coming from. very strange. someone said do a compression test, because the compression may be low, thus creating a low vaccum, so its not pulling fuel. anyon have any ideas? id really hate to have low compression right now as its for sale...
I would most definitely just pull the carbs off completely, and clean them out with carb cleaner and compressed air, but be sure to blow the dirt OUT and not INTO crevices. Also, make sure you unplugged ALL the TORS connectors.
Later.
Well, that's it. Either the pilot circuit it clogged or jetted wrong, your choke circuit has something wrong with it or low compression.
Is the bowl with the brass tube on the left carb for sure? That'll make the choke not work. Choke tube is between the carbs .. right?
