ok, yeah im sorry about that. ok its a 98, cool head, boost bottle, (stock) twin carbs, jetted, reeds, dg pipes and silenecers, stock air filter. i only took off the main carb, the one with the choke. when i took the bottom peice off, where the floats are, and where the jet is, gas came pouring out of that. im not stupid, i turned off the gas line so it wasnt coming from the tank. after dumping the gas out of the carb, i put it back on, and figured if they were both that flooded, at least emptying one would be enough to make a difference. so i put it back on, and started kicking. nothing. so the first thing you check are gas, which i knew i was getting, so i pulled the plugs, and kicked it over. no spark.
