jonnyrebel2004 Posted January 2, 2005 Report Posted January 2, 2005 I am needing to buy a flywheel puller for my 2000 Banshee. I have looked on the internet and different web sites give different size pullers they say will fit it. I was wondering if anyone knew what size fits it. (i.e. mm x mm, internal or external, and right or left hand thread). Does anyone have one they would be willing to sell me? Thanks Travis Quote
Otis Posted January 2, 2005 Report Posted January 2, 2005 (edited) It's the top one....i dont know the specs, but it should say on there. motion pro tools Edited January 2, 2005 by Otis Quote
Dr. Overkill Posted January 2, 2005 Report Posted January 2, 2005 It's only $9.99 at Alba (although I don't know what their shipping will run). http://alba.buyol.com/Item/DS001001.htm _dennis Quote
NugShee Posted January 2, 2005 Report Posted January 2, 2005 will the universal puller work? the one with the 3 arms that wrap around the flywheel and then you screw in the middle bolt. the middle bolt pushes in the center shaft while the 3 arms pull on the outside of the flywheel. You can find those pullers all over but im not sure if they will work or cause damage to the flywheel. maybe someone who has used one can let us know if they work. Quote
boonman Posted January 2, 2005 Report Posted January 2, 2005 HEREis a puller on Ebay. Check it out... Quote
DIRTBIKEZ Posted January 3, 2005 Report Posted January 3, 2005 will the universal puller work? the one with the 3 arms that wrap around the flywheel and then you screw in the middle bolt. the middle bolt pushes in the center shaft while the 3 arms pull on the outside of the flywheel. You cannot use a 3 jaw puller or any other puller besides the ones Otis and boonman described. I bought one on ebay and the peice of shit stripped out on me first time using it... bought the MotionPro next and it's worked flawlessly Quote
jonnyrebel2004 Posted January 3, 2005 Author Report Posted January 3, 2005 Ok I will look around and see what I can find. Guys thanks for all your help. Travis Quote
