banshee88 Posted January 1, 2005 Report Posted January 1, 2005 i just built a banshee and had the lights hooked up and running fine. i have 35watt gytr lights and 35watt piaa handlebar lights. the smaller ones being connected to my low switch and the other ones on high.at first i had both hooked to the same but the power was weak so we switched them to high low. the problem is the lights do not come on now. i checked the regulator,coil, cd iand the connections. i'm using a brand new factory harness so there should be no problems there. the banshee runs fine just doesn't have lights. could it be in the stator/flywheel area? please help i'm out of ideas? thanx alot all the bulbs are good Quote
tsuther78 Posted January 1, 2005 Report Posted January 1, 2005 Did you check your voltage regulator? I had the same problem. Both lights and the tail light just went out. Come to find out I blew the voltage regulator Quote
