H250RHATER Posted January 1, 2005 Report Posted January 1, 2005 it could be ur spark plug wires on the wrong cylenders because each cylender has a different timming for spark well whatever it is i hope u get it runin looks like a nice bike Quote
Banchetta Posted January 1, 2005 Report Posted January 1, 2005 it could be ur spark plug wires on the wrong cylenders because each cylender has a different timming for spark well whatever it is i hope u get it runin looks like a nice bike 300599[/snapback] Both plug wires fire at the same time. Thats why I already suggesting to swap plug wires. If the opposite cylinder acts up, then its his plug wire or coil...If that doesn't change anything, then its not the coil or wires.. Quote
BansheeEaterKXF Posted January 1, 2005 Report Posted January 1, 2005 i had the same problem ran messed up idled but hit the gas an bla it stalled then it would start for a sec then bla then it would run great for about 25-30 secs then bla so i was like oh i have an air leak nope that 35 carb needed the floats set it was not getting enough gas but the plugs were wet when i checked them so i just went threw the carb an set it perfect runns like a champ now set your floats at 16mm from the bottom of the float bowl to the top of the floats Quote
BansheeBoy17 Posted January 2, 2005 Author Report Posted January 2, 2005 (edited) Well i switched the plug caps tonight and the problem didnt switch sides... I really doubt its my floats because it started doing this whlie I had my stock carbs on, and it continues to do it even after i put my trinity 2into1 intake with 35mm Mikuni on.... I have checked pretty much everything. Pistons still look like new too, not even any carbon build up on them yet since they only have about 14 hours on them. Well... no progress yet..... and i still have NO clue what it could be. The ONLY thing I could think of is MAYBE my right rod bearing is bad, ... and since the cylinder only fires when the choke is out (more gas) maybe it gets enough energry to fire then because of all the gas... also, it only starts with a forceful , fast kick ... if u guys get what I am saying? Edited January 2, 2005 by BansheeBoy17 Quote
Banchetta Posted January 2, 2005 Report Posted January 2, 2005 Do a leakdown test...that'll eliminate about 20 probabilities... Quote
BansheeBoy17 Posted January 2, 2005 Author Report Posted January 2, 2005 Do a leakdown test...that'll eliminate about 20 probabilities... 300844[/snapback] Never done one of those before, I asked some of my buddies and none of them knew for sure either... can you tell me how it works? Quote
tOj Posted January 2, 2005 Report Posted January 2, 2005 (edited) Clicky Clicky <-------------------------- Try that out it seems to be a good little article on leak down tests. Try this one too, gives pictured details as well. Click meh >_< Edited January 2, 2005 by tOj Quote
