cudaz101 Posted December 27, 2004 Report Posted December 27, 2004 (edited) OK...I ride in the woods mostly...I will have FMF pipe set & proper jet set only for now...The rest of the bike is pretty much stock. I ordered me a 13 front and a 43 Rear...??? I have 22" tires... Brad Edited December 27, 2004 by cudaz101 Quote
cudaz101 Posted December 27, 2004 Author Report Posted December 27, 2004 (edited) OK...I ride in the woods mostly...I will have FMF pipe set & proper jet set only for now...The rest of the bike is pretty much stock. I ordered me a 13 front and a 43 Rear...??? Edited December 27, 2004 by cudaz101 Quote
sredish Posted December 27, 2004 Report Posted December 27, 2004 Personally, I think that'll be a PITA in the woods, being too low. You'll be shifting a lot. I'd try 14/40 to 15/41 and see if one of those works best for you. In my experience in the woods, stretching the gears makes it easier and me faster rather than a lower gear that causes me to shift a lot. With my portwork, I'm at a 15/38 and it works great that way ( a 15/38 is equal to a 16/41). Before with my stock motor and FMF pipes, I ran a a15/41 and it worked great for me. You'll probably using a gear lower than you did before, but you should be able to pull it longer. My opinion. Quote
cudaz101 Posted December 27, 2004 Author Report Posted December 27, 2004 Personally, I think that'll be a PITA in the woods, being too low. You'll be shifting a lot. I'd try 14/40 to 15/41 and see if one of those works best for you. In my experience in the woods, stretching the gears makes it easier and me faster rather than a lower gear that causes me to shift a lot. With my portwork, I'm at a 15/38 and it works great that way ( a 15/38 is equal to a 16/41). Before with my stock motor and FMF pipes, I ran a a15/41 and it worked great for me. You'll probably using a gear lower than you did before, but you should be able to pull it longer. My opinion. 298496[/snapback] Thanks MAN...15/41 on the way.... Brad Quote
sredish Posted December 27, 2004 Report Posted December 27, 2004 Let me add that in the really really tight stuff, I'd run a 15/42. I'd just switch out the rear and be flyin again. That'd gear it a tad lower, just enough that I could hold 3rd gear in the tighter stuff. I like the 15 front and just swap out rears to gear it the way I need. Although, I need to take a link out to get the chain tightened just right for the 15/38, chain's a tad loose right now, so I might go back to a 15/39. Gearing is all personal preference and trial 'n error. Put on the 15/41 and it may be perfect, or maybe a tad too high for what you want, just try it and then see. Later Quote
