Hey guys, I was just dicking around with this damn thing for 2 hours and still can't get the alen head screw to go into the other end of the chain slider :( Please, if you know any way to get one of these things together, let me know, Thanx!
Here is a pic!
Not trying to sound like Captain Obvious....but you did remove the old slider didn't you? :unsure: Other than that, it looks pretty self explanatory. I had the cascade style similar to that, but had to remove the swingarm to put it on...that's the nice thing about the one you got there, not having to remove the swinger. However, you're the 1st person I've heard from that's had any problems. Wish I had a good suggestion other than making sure the old slider ring is not on there & there's nothing binding it up. :shrugani:
I have the same UPP slider. Pull it back off the arm and make sure the hole is threaded correctly in the main portion of the slider, then re-install on the swinger and make sure you line the bolt up accordingly, should only take 2 minutes ...
Yep had the same damn problem myself. It was a total pain in the azz to line up the hole where the screw goes. I just used a lot of force then went right in. Was not near as easy as you would think. Sheesh some of the things that appear so simple can really piss you off.
Nylon like that can get all sorts of funny when tapped out. The threads NEVER like to start in a fashion that is appeasing to the end user. What happens is that the tap starts getting a touch dull, and instead of cutting the threads, it kind of "forms" the threads. In other words, it mushes the material out, and once the tap is removed, the material shrinks some, and makes the screw go in really tight. Bummer, but that's the lay of the land with plastics and threads.....
It came with dirctions. I removed the factory slider and ring and the damn thing will not close all the way and let me put the alen head screw in. It is totally mis aligned when I wrapped it around the swinger and tried to force it shut to put the screw in. I am tempted to just run a sheet metal screw right into it and not worry about it.
