Just a few quick questions. How difficult is it to remove the old studs and replace with the longer studs. Also what is the procedure for doing this. Also with domes what is the best size to use for sand dune riding at sea level. All suggestions and input greatly appreciated. Thanks
Well, if you get a noss head you don't have to mess with the studs. Also, he can guide you in the direction of what size dome for your elevation.
If you do need to remove the studs, just put two nuts together tight. Then you can use the bottom one to get the stud out.
