Cindied Posted December 8, 2004 Report Posted December 8, 2004 I HAVE KEIHIN 35MM CARBS AND NEW V-FORCE REED CAGE. THE BOTTOM OF MY LEFT CARB IS RUBBING ON THE TOP OF THE CLUTHCH RELEASE SHAFT. SO WHEN I PULL MY CLUTCH IN, MY CARB MOVES. ANY CLUE OF HOW TO FIX? Quote
fixitrod Posted December 8, 2004 Report Posted December 8, 2004 I HAVE KEIHIN 35MM CARBS AND NEW V-FORCE REED CAGE. THE BOTTOM OF MY LEFT CARB IS RUBBING ON THE TOP OF THE CLUTHCH RELEASE SHAFT. SO WHEN I PULL MY CLUTCH IN, MY CARB MOVES. ANY CLUE OF HOW TO FIX? 290613[/snapback] Have the bowl cut and welded.... or, you could trade me. I have a welded keihin 35mm pwk bowl and have been looking for someone to trade with. You can also get reed spacers but it may not run the same. Quote
kenr74 Posted December 8, 2004 Report Posted December 8, 2004 I have some 1/2 spacers if you want them. $10 shipped. Quote
cdw Posted December 8, 2004 Report Posted December 8, 2004 Just bend the arm down some on the shaft. Quote
Justintoxicated Posted December 9, 2004 Report Posted December 9, 2004 Just bend the arm down some on the shaft. 290660[/snapback] When I got my PWK's someone had ground down the bolt some. It was enough to clear the arm, (not by much) but some simple grinding took care of it. Only issue you will have is that you will have to rejet the carbs like the stock one (remove the whole bottem) but it's still easy as pie. Quote
Cindied Posted December 9, 2004 Author Report Posted December 9, 2004 When I got my PWK's someone had ground down the bolt some. It was enough to clear the arm, (not by much) but some simple grinding took care of it. Only issue you will have is that you will have to rejet the carbs like the stock one (remove the whole bottem) but it's still easy as pie. 290871[/snapback] Quote
Cindied Posted December 9, 2004 Author Report Posted December 9, 2004 I gounded down the bolt and bent the arm down a little. Now it clears. THANKS FOR YOUR ADVISE Quote
bogart Posted December 10, 2004 Report Posted December 10, 2004 I gounded down the bolt and bent the arm down a little. Now it clears. THANKS FOR YOUR ADVISE 291216[/snapback] was just having the same problem with the rz motor and 34mm carbs Quote
