Few questions.. Yes im full of them.. im learning :P
Anyhow i bought brake pads off ebay 90-01 YFZ350 Banshee Brakes Pads front and rear
*had a dumb ass attack and thought I had a 2000..
I have a 2002 banshee so will those work on mine?
Also my rear brakes QUIT and i wreaked..
I pushed the foot break down had breakes then it just felt like someone let a bunch of air in the line and no more brakes.. the resivor is full of break fluid..
My brakes was makes grinding noises so i need a new brake rotor but why the loss of breaks? :cry:
those pads should work fine sounds like need a little bleeding before you get back on the shee. as for the rotor, check it out. if its filled with scratches and deep scars its time for a new one. if its still relatively smooth use a micrometer to measure its thickness. it has a minimum measurement thats stamped into the side of it. if you measurement is smaller than that one its time for a new rotor. if not you are A-OK.
I can't get my front brakes to work.  I refilled them and bled them.  But there is still no pressure.  What should I do? Please help.
:evil:  :bolt:
290413[/snapback]
keep on bleedin til they feel good. sometimes it takes alooooong time.
