i used the stock rubber hoses. they were a bitch to get on there. they dont leak so i guess ill keep using them, they just dont look as nice as billet clamps.
288885[/snapback]
Wut he said
:headbang:
Damm,I made & sold 30+ sets for the fatties,but don't know the specs for the Rockets.But I,m planning on buying a set after Christmas,will make me a set for shure.This is an aluminum collar w/ o rings.Let me know if interested.
Edited by duner
I have a set of stinger to pipe seals made by chozen performance that work very well and look really nice. You can see them on page 6 of the banshee parts on chozenperformance.com. They don't list a set specifically for Rockets but they do make the correct size, you just need to measure the stinger tube and expansion chamber outlet diameter and figure out which one will fit. They are one piece aluminum with an o-ring seal on either end. They just slide on tight, no clamp. They have a step inside; 2 diameters, one for the stinger, one for the expansion chamber. I had to trim about 1/4 inch off of the stinger tube because it wouldn't go into the seal far enough for the silencer to mount. Check out the pics below.
Kinda dissapointed to see that,from my end.They look simalar to mine,(mine are straight with about a 1/4'' bevel on each end).This design of clamps works very well if Viton O Rings Are used.The price looks right too. Nice clamps Ducman.
289495[/snapback]
The chosen performance seals aren't cheap, if you've made similar seals on a lathe before, I'm sure you could probably make them, sell them for less at a good profit. Also, like I said the seals require you to modify the stinger tubes (shorten) to fit, you could make them so no trimming is required. Basically now my Rockets must me used with the seals I have. Minkia38 (Ray) might be interested in a few sets for Rocket customers if he hasn't already arranged to have a few sets made himself.
