is there a trick to removing the tierods from the arms and stem...i need to get my frame to the powder coater and i cant get them off. please help...thanks
You can use / rent a "tie rod puller" from an auto parts place, or just smack the side of the stem & spindle with a dead blow ball peen hammer. Make sure the castle nuts are loose first and do not hit the threaded potion. Good luck
  • 11 months later...
heres an easy way to do it.... put the nut back on about a thread maybe two so teh nut sticks above teh stud.... then get a punch and the nut will keep it form popping off the stud when you hit it with the BFH... been doing it that way for years never had a problem...
