How hot is shee getting?
Vent line/gas cap can cause problem, but usually doesn't take a half hour. Check your fuel and vent for the hell of it.
if you pull your seat and look close theres a slot for quarters, with a little timer by it, you just have to carry a little change purse with you when you ride......
Well shit, that's probably it. I was thinking fuel-pump, but... :shrugani:
Someone suggested that coils can go down once theyre hot - is this true ?
If it's not fuel related, then I'd check the coil for sure, possibly cdi--dunno though, kinda weird symptoms you have there.. Have you cleaned your fuel petcock?
Sounds like something electrically is going bad. May be coils,cdi, or the insulation of the stator is breaking down. You got to get it to run and cut-off like it does then test those components. Maybe bad wires not contacting eactothe when they expand from heat. Not sure but definatly sounds electrical.
once i saw the topic i thought electrical too...is the key switch bypassed by any chance? my cousin lost his key and just hotwired it....fried the cdi..
could also be the coil or the stator
tors still hooked up?
