BansheeWanted Posted November 18, 2004 Report Share Posted November 18, 2004 Hi Guys Just rebuild the engine and get new seal and bearing for the crank ... its run so far .. but one pipe smoke than the other..why is that ? Quote Link to comment Share on other sites More sharing options...
4strokekiller Posted November 18, 2004 Report Share Posted November 18, 2004 check the spark plugs and see if they are fouled, also make sure that your carbs are in sync Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted November 18, 2004 Report Share Posted November 18, 2004 (edited) also make sure that your carbs are in sync 282519[/snapback] Also that means not just the slides being in sync, but the idle screws as well. My pipes were smoking unevenly and I realized that one carb was slightly off from where the other was (idle screw). Got them synced, started smoking evenly... How does it run like it is now? Edited November 18, 2004 by bigboybanshee Quote Link to comment Share on other sites More sharing options...
sweetshee4312 Posted November 18, 2004 Report Share Posted November 18, 2004 my pipes were doing this, just look down into the throat of the carbs, and making sure the slides are even(same height), then i bet it will run perfact, casue mine was the same way. Quote Link to comment Share on other sites More sharing options...
dunesavvy Posted November 21, 2004 Report Share Posted November 21, 2004 I'm not trying to be a d**k or anything but just because you replaced the seal does not mean it was done correctly. Everybody makes mistakes sometimes, that's why pencils have erasers. Recheck your work. Cheers! Quote Link to comment Share on other sites More sharing options...
