kotin6 Posted November 13, 2004 Report Posted November 13, 2004 I have bought all the above. What am i going to need when it gets here to install. I know i need a gasket for the cover. Quote
RNBRAD Posted November 13, 2004 Report Posted November 13, 2004 I have bought all the above. What am i going to need when it gets here to install.I know i need a gasket for the cover. 280330[/snapback] If it's the outer clutch cover you won't need anything. If it's the clutch case cover then yes you will need a gasket. Otherwise for the outer clutch cover and waterpump cover, they come with all the hardware you need for those. So you may need oil to refill gear case, new gasket and threadlock for ALL the bolts. Quote
kotin6 Posted November 13, 2004 Author Report Posted November 13, 2004 (edited) yea its the clutch case. Edited November 13, 2004 by kotin6 Quote
superchicken Posted November 13, 2004 Report Posted November 13, 2004 will it come with a waterpump bearing?if not your gonna have to get one and it would be a good time to put a billit impeller in it.oh,almost forgot the waterpump gasket.wile you have it apart ajust the clutch if ya have to Quote
kotin6 Posted November 13, 2004 Author Report Posted November 13, 2004 not sure what a waterpump bearing is but if it is an actual thing i hope i can get off my stock. Not worried about a billet impeller since noone can see it and my stock works fine. As far as I know my clutch doesnt nee adjusting but i wouldnt know how to if i did . Im in Italy so i cant get parts and its my first quad so im kind of novice. Evreything I have done to it so far has been done by me but I never know what to expect when i start a project on it. Quote
